Drakey wrote:Jensen will be pushed hard by Olejniczak. I think the Bulldogs would be better with him in the lineup immediately, but I'm sure it won't happen. Drake should be playing at least ten guys through all of the non-conference as it does not appear that there is much separation.
AndShock wrote:I did not realize Enevold was only an upcoming junior. He has a chance to be a beast by the time he's done. I also did not realize his last name was Jensen.
Wufan wrote:Drakey wrote:Jensen will be pushed hard by Olejniczak. I think the Bulldogs would be better with him in the lineup immediately, but I'm sure it won't happen. Drake should be playing at least ten guys through all of the non-conference as it does not appear that there is much separation.
Two interesting things in this post:
1. Drake has two young 7 footers that can play. I've seen some highlights of the incoming Eurofrosh, and the kid is agile, coordinated and skilled. Good chance that the Bulldogs dominate the paint often.
2. No separation between first string and second string. The problem I see here is that most of the talent seems like second string talent. Most of the guys are freshman and sophomores so improvement could be coming in leaps and bounds in some players, but Drake needs a go-to star (probably two) to elevate above middle of the conference. It seems that everyone on the team is either a wing guard or a center.![]()
Woodward and Abrahamson I suspect will be good players. Both are P5 transfers and are older than the majority of the team.
sixth ace wrote:Evansville will have start
Ballentine
Brown
Wing
Simmons
Mockevicius
off the bench will be Gibson at point and Wiley at forward
Users browsing this forum: No registered users and 31 guests
