Shock Earl Watson not eligible.
Re: Shock Earl Watson not eligible.
Postby RoyalShock » September 4th, 2013, 12:11 pm
Bradleyfan1 wrote:
Aargh wrote:Bf1, Geno should put you on his staff. You could have told him not to waste his time recruiting Carter.
Because I said he wasnt worth recruiting. sarcasm because I did not say that.
Carter played on a better team than Watson. (Vincennes was better than Chipola). Carter had better stats than Watson. Watson was an early season starter, but lost his starting spot as the season progressed.
Yes Carter played on a better team. Which also plays a part in his stats being better.
Carter averaged something like 18 points per game in the NJCAA tourney. Watson is an inch taller and everyone considers him freakishly athletic, but Carter had better rebounding stats.
Watson is 10 lbs heavier too and yes is more athletic, hes Bigger,Stronger and Faster.
Chadrack Lufile is probably bigger, stronger and faster. But that doesn't make him a better basketball player.
You can play bigger, be stronger and be faster, but if you're doing at the wrong spot on the floor, missing the shot, throwing the pass away or out of position on the rebound, what good did all those physical superiorities do?
RoyalShock
Postby Bradleyfan1 » September 4th, 2013, 4:56 pm
Im sure or atleast I hope GM would have either of them in the right spot.
Its all speculation at this point.
No way we will ever know unless Watson can get eligible!
In a game of one on one my money is on Watson! And that is the favorite in this "pick em" game.
Bradleyfan1
Postby Wufan » September 4th, 2013, 4:59 pm
Bradleyfan1 wrote:Im sure or atleast I hope GM would have either of them in the right spot.
Just curious, but how many of Watson's games have you seen?
How many of Carter's?
Postby Bradleyfan1 » September 4th, 2013, 10:55 pm
No more than a hour or so of footage of Carter . Mostly watching DD
Even less for Watson I dont get to Fl much to watch JUCO ball.
Bradleyfan1
Postby rlh04d » September 4th, 2013, 11:07 pm
Bradleyfan1 wrote:No more than a hour or so of footage of Carter . Mostly watching DD
You've literally spent longer on here talking about these players than you've spent watching them.
Users browsing this forum: Google [Bot] and 13 guests
